BlueVNA V0.8 Feedback
Re: BlueVNA V0.8 Feedback
Yes I think you understand
In TRANSMISSION CALIBRATE the pop up window says to "connect open reference to DET.
Should this say to connect DET to DUT with short cable?
tnx
Barry
tnx
Barry
When I try to do transmission calibrate a pop up
tells me to connect open to DET.
Should this say to connect DUT to DET with short cable?
tnx
Barry
tnx
Barry
Hi Barry,
Ooops. You're right. The message is wrong for miniVNA standard.
I've corrected this and will be included in the next update.
Thanks for reporting this bug.
Hi Barry,
I forgot to ask you if you are using miniVNA standard over Bluetooth or over USB.
miniVNA / USB / ASUS TF300T
Barry
Barry
Great!
So USB is working now for you too and the tablet is able to power it up.
Thanks.
Thanks.
Calibration completed.
Initial tests on antenna looking good.
Barry
Barry
Hi Barry,
Great!
You can compare the results with other Windows applications to see if they are the same.
Great!
Have run analyzer functions on my 3el es my Butternut HF9V vertical.
Everything is looking great.
Barry
Barry
Thank you Barry.
