RA6LFJ
Post by RA6LFJ » Thu Nov 02, 2017 1:16 pm
Thank you! working! I continue to study!
Post by yo3ggx » Thu Nov 02, 2017 2:28 pm
If you have any other issue, just post a message here and I will do my best to help.
Good luck,
RA6LFJ
Post by RA6LFJ » Thu Nov 02, 2017 4:01 pm
Thank you! version of Pocket RxTx version 0.9.0-20 is not stable! When you connect, you turn on the scan.
Новый точечный рисунок (6).jpg (69.3 KiB) Viewed 3200 times
Post by yo3ggx » Thu Nov 02, 2017 8:17 pm
Please be aware that in version 0.9.x , when you start the application, all the button status are automatically applied, in order to revert to the status before last close
ba7ib
jaracmini can't recognition USB soundcard
Post by ba7ib » Sun Jan 07, 2018 3:52 pm
Some infomation show:
root@DietPi:~# lsusb
Bus 001 Device 006: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 005: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 001 Device 004: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@DietPi:~# java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
root@DietPi:~# java -jar jarecmini.jar
jAReC mini version 0.9.0-17
Current settings:
TCP port: 4442
Baudrate: 38400
CAT Port: /dev/ttyUSB0
PTT Port: /dev/ttyUSB0
Use Audio: true
Power over RTS: false
Power over DTR: false
PTT Mode: CAT
Secret Hash: 0A71AACD02C0BB123B818D0B6D36D6E7F84AC51E
Audio Out Interface: (0) - ALSA [default]
Audio In Interface: (3) - Set [plughw:1,0]
Use authentication: false
Available com ports:
/dev/ttyAMA0
/dev/ttyUSB0
Available Audio IN devices:
(03) Set [plughw:1,0]
Available Audio OUT devices:
(00) ALSA [default]
(01) ALSA [plughw:0,0]
(02) ALSA [plughw:0,1]
If ok, set bAutostart=true in the jsn.cfg file and run again
root@DietPi:~# java -jar jarecmini_v0.9.0-18.jar
jarecmini version 0.9.0-18 (2018/01/07--21:47:51)
Current settings:
TCP port: 4442
Baudrate: 38400
PTT Port:
Use Audio: true
PTT Mode: CAT
/dev/ttyAMA0
/dev/ttyUSB0
(00) ALSA [default]
Unsupported devices:
(04) Port ALSA [hw:0]
(05) Port Set [hw:1]
then I run it:
jarecmini version 0.9.0-18 (2018/01/07--21:50:19)
Listening for connections on 192.168.103.97:4442
invalid audio interface
Invalid audio selection!
Remote IP: 10.108.21.30
NoOp received
NET disconnected!
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Aborted
Post by yo3ggx » Sun Jan 07, 2018 6:14 pm
It seems you selected a wrong audio interface, not available to the Java subsystem. Try to connect an USB audio device and check with that one. Sometimes the internal one does not work. I have the same issue with Orange Pi.
ba7ib
Post by ba7ib » Mon Jan 08, 2018 4:30 am
but why the soundcard can be recognized by ver0.9.0-17
Post by yo3ggx » Mon Jan 08, 2018 9:07 am
I know, I have the same issue with RPi and internal audio. I can see the device listed, but in reality is not available to the java subsystem. I was not able to find the root cause yet, so I'm using a cheap USB audio interface.
ba7ib
Post by ba7ib » Mon Jan 08, 2018 9:42 am
Roger
so, could you post your USB soundcard using which chipset? lsusb...
ba7ib
Post by ba7ib » Thu Feb 08, 2018 8:08 am
Do you have a project to rewrite jAReC_mini with python ? @yo3ggx
