jarecmini on a raspberry
balans
Post by balans » Tue Sep 22, 2015 9:07 pm
Hi i am still in a beta stadium but i wanted to share my findings so far
I installed raspbian 2015
plugged in my USB PnP Audio Device since the raspberry does not have line or mic in.
check with the command alsamixer
toggle with F6 to see your usb card example USB PnP Audio Device or somewhat simulair
tune youre input and output levels up and exit
type alsactl store to save the settings
download jarecmini.zip
unpack and edit jsn.cfg
sCOMport=COM6
to
sCOMport=
and save
execute java -jar jarecmini.jar
and if al is ok you should see something like this
jAReC mini version 0.8.1
Please set valid Serial port in the jsn.cfg configuration file
IInvalid audio device
Current settings:
COM Port:
Baudrate: 38400
TCP port: 4443
Use audio: true
Play Interface: (0) - Device [default]
Use authentication: true
Secret: 2743C71E3828333B277A8FE65050595BF13DD669
Available com ports:
/dev/ttyAMA0
/dev/ttyUSB0
Available Audio IN devices:
(03) Device [plughw:1,0]
Available Audio OUT devices:
(00) ALSA [default]
(01) ALSA [plughw:0,0]
(02) ALSA [plughw:0,1]
If ok, set bAutostart=true in the jsn.cfg file and run again
edit jsn.cfg
sCOMport=/dev/ttyUSB0 ( i use an external usb cable)
now notice the numbers with the Audio in and Out and edit these lines
iRecInterface=3
iPlayInterface=0
the 0 come off , and then save and execute again
root@raspberrypi:/home/pi/Downloads# java -jar jarecmini.jar
Listening for connections on 192.168.1.28:4443
Remote IP: 192.168.1.232
Start Audio
and then use Pocketrxtx to connect
I had to use the default audio out connector on the raspberry but the mic/line in works from the usb
I tried to make the audio out from the usb but failed miserably , but this way it worked so far and thats ok with me.
I do still have a problem with the CAT and my FT817 it starts with TX when jarecmini starts.
when i use pocketrxtx the audio from the mic works , when i start jarecmini with the CAT cable disconnected from the FT817
I have audio from the set on my android smartphone true Pocketrxtx.
So this projects looks very promising for a lowcost lowpower remote solution.
I hope to figure out whats wrong with the cat on my side or with Dan on the jarecminiside
Re: jarecmini on a raspberry
Post by yo3ggx » Tue Sep 22, 2015 9:25 pm
Great!
Thank you for sharing your experience with the other users.
kd4kso
Post by kd4kso » Fri Nov 11, 2016 4:47 pm
I am new to Linux can you tell me how to unpack and edit jsn.cfg ? I get an error telling me to create jsn.cfg.
Post by yo3ggx » Fri Nov 11, 2016 5:44 pm
kd4kso wrote:I am new to Linux can you tell me how to unpack and edit jsn.cfg ? I get an error telling me to create jsn.cfg.
You can follow the procedure described in the jarecmini user guide available here:
https://www.yo3ggx.ro/jAReC/doc09016/jA ... 9.0-16.pdf
Hope this help.
kd4kso
Post by kd4kso » Fri Nov 11, 2016 6:44 pm
I read that but doesn't tell me where I find the jsn.cfg file. I unzipped the file I downloaded and there was one file there. When I try to open it I am told to create the jsn.cfg file.
kd4kso
Post by kd4kso » Fri Nov 11, 2016 8:38 pm
I went back and downloaded jarec v8 and the jsn.cfg file was in that zip file. I have it going now just trying to get the network connection figured out.
de kd4kso
Post by yo3ggx » Fri Nov 11, 2016 11:27 pm
kd4kso wrote:I went back and downloaded jarec v8 and the jsn.cfg file was in that zip file. I have it going now just trying to get the network connection figured out.
Yes, this is the easiest way to build a config file and currently the only way to set the password hash.
What's the issue with the network?
kd4kso
Post by kd4kso » Sat Nov 12, 2016 4:54 pm
Sorry I put this in another thread
OK I got the jsn.cfg file from version 8 of jAReC. I set it up and run jarecmini.jar
pi@kd4kso:~/Downloads/jARec $ java -jar jarecmini.jar
Listening for connections on 192.168.0.234:4443
main._appstart (java line: 279)
The I start Pocket RxTx on my Andriod tablet and when I try to connect the console on the Pi does this:
java.lang.RuntimeException: java.lang.NoClassDefFoundError: javafx/beans/value/ChangeListener
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:114)
at anywheresoftware.b4a.BA$3.run(BA.java:178)
at anywheresoftware.b4a.keywords.SimpleMessageLoop.runMessageLoop(SimpleMessageLoop.java:30)
at anywheresoftware.b4a.StandardBA.startMessageLoop(StandardBA.java:26)
at anywheresoftware.b4a.keywords.Common.StartMessageLoop(Common.java:131)
at b4j.example.main._appstart(main.java:279)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:93)
at anywheresoftware.b4a.BA.raiseEvent(BA.java:84)
at b4j.example.main.main(main.java:29)
Caused by: java.lang.NoClassDefFoundError: javafx/beans/value/ChangeListener
at b4j.example.main._mysrvsock_newconnection(main.java:693)
... 12 more
Caused by: java.lang.ClassNotFoundException: javafx.beans.value.ChangeListener
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 18 more
I tried running jAReC v 9 with the same jsn.cfg and it won't recognize the comm port. I have the file set to /dev/USB0
pi@kd4kso:~/Downloads/jARec $ java -jar jAReCmini_v0.9.0-16.jar
jAReCmini0.9.0-16
Current settings:
COM Port:
Baudrate: 38400
TCP port: 4443
Use audio: true
Play Interface: (0) - ALSA [default]
Rec Interface: (3) - CODEC [plughw:1,0]
/dev/ttyAMA0
/dev/ttyUSB0
java.lang.NullPointerException
(03) CODEC [plughw:1,0]
(00) ALSA [default]
This is what the cfg file actually says:
#Wed Sep 02 14:29:27 EEST 2015
bUseAuthentication=true
sHSecret=2743C71E3828333B277A8FE65050595BF13DD669
sBaudrate=38400
bUseAudio=true
bAutostart=true
nwPort=4443
iRecInterface=3
iPlayInterface=0
Post by yo3ggx » Sat Nov 12, 2016 7:47 pm
kd4kso wrote:Sorry I put this in another thread
Please confirm that you are trying to use jarecmini 0.8.x with Pocket RxTx 0.8.x
Take care that version 0.8 config is not good with 0.9.0-16, as some parameters are missing:
sPTTport=...
PTT=...
Please check jAReC 0.9.0-16 user guide here:
at page 7 (configuration file)
Pocket RxTx 0.9.0-18 require jAReC 0.9.0-16, is not compatible with previous versions.
It looks like it tries to use javafx which is not available on your Raspberry Pi.
Please check the new parameters for 0.9.0-16.
kd4kso
Post by kd4kso » Sat Nov 12, 2016 10:03 pm
OK I have that part now. I copied the information to the cfg file. You told me to use jAReCmini. When I try to run the jarecmini file it doesn't see that I have a comm port listed. When I remove the jsn.cfg file and run it for the first time like the mini manual says it does not create the the file but instead tells me to create one. This is what my config file says
#Wed Sep 21 17:12:29 EET 2016
bUseEncryption=false
iPTTtimeout=30
sBaudrate=38400
sPTTport=/dev/ttyUSB0
bAutostart=false
iPlayInterface=4
PTT=RTS
bUseAudio=true
iRecInterface=8
nwPort=4444
bRTSpower=true
bDTRpower=false
