Yaesu radios config files
Re: Yaesu radios config files
Post by yo3ggx » Fri Sep 25, 2015 3:31 pm
Please check the thread about FT817 config file, maybe can help:
http://www.yo3ggx.ro/forum/viewtopic.php?f=15&t=574
Repeater commands are added there.
Re: AW: Yaesu radios config files
Post by MysticFire » Fri Sep 25, 2015 8:21 pm
For me now works rpt complete. Ctcss and setting of frequency too. Now i start script dcs codes. DCS and CTCSS is switchable on off and rx open but tx with ctc or dcs
http://www.mumble-funk.de - Freier Funk für PC/Android/Iphone
Post by MysticFire » Fri Sep 25, 2015 10:07 pm
Here now my actual config. All CTCSS and all DCS Codes included. Repeater for 100 khz (10 m), 600 khz,1,6 MHZ and 7,6 MHZ included.
Brand=Yaesu
Model=FT857
sigRadios=$1gR@d10s
; Frequency coverage
FRANGE=100000-56000000,76000000-108000000,118000000-164000000,420000000-470000000
; List of available Bands
BANDS=160m,80m,40m,30m,20m,17m,15m,12m,11m,10m,6m,4m,2m,70cm
; first wheel - list of available modes in the MODE wheel (starts with wheel name)
LST1NAME=MODE
LST1ITEMS=LSB,USB,CW,CWR,AM,FM,FM-N,DIG,PKT
LST1CMDS=CMD_SET_MODE_LSB,CMD_SET_MODE_USB,CMD_SET_MODE_CW,CMD_SET_MODE_CWR,CMD_SET_MODE_AM,CMD_SET_MODE_FM,CMD_SET_MODE_FM-N,CMD_SET_MODE_DIG,CMD_SET_MODE_PKT
; second wheel - list of available powers in the PWR wheel (starts with wheel name)
LST2NAME=PWR
LST2ITEMS=0.5W,1.0W,2.5W,5.0W,20.0W,45.0W,75.0W,100.0W
LST2CMDS=CMD_SET_PWR_0.5W,CMD_SET_PWR_1.0W,CMD_SET_PWR_2.5W,CMD_SET_PWR_5.0W,CMD_SET_PWR_20.0W,CMD_SET_PWR_45.0W,CMD_SET_PWR_75.0W,CMD_SET_PWR_100.0W
; Option Button config (name,odd_press_cmd,even_press_cmd,odd_press_label,even_press_label
BTN_OPT1_NOFN=VFO,CMD_SET_VFO_TOGGLE=AB
BTN_OPT2_NOFN=
BTN_OPT3_NOFN= SQMOD,CMD_SET_CTCSS_OFF=OFF,CMD_SET_DCS_ON=DCSON,CMD_SET_DCS_TXON=DCSTX,CMD_SET_CTCSS_ON=CTCON,CMD_SET_CTCSS_TXON=CTCTX
BTN_OPT4_NOFN=CTCSS,CMD_SET_CTCSS_67=67,CMD_SET_CTCSS_69.3=69.3,CMD_SET_CTCSS_71.9=71.9,CMD_SET_CTCSS_74.4=74.4,CMD_SET_CTCSS_77=77,CMD_SET_CTCSS_79.7=79.7,CMD_SET_CTCSS_82.5=82.5,CMD_SET_CTCSS_85.4=85.4,CMD_SET_CTCSS_88.5=88.5,CMD_SET_CTCSS_91.5=91.5,CMD_SET_CTCSS_94.8=94.8,CMD_SET_CTCSS_97.4=97.4,CMD_SET_CTCSS_100=100,CMD_SET_CTCSS_103.5=103,5,CMD_SET_CTCSS_107.2=107.2,CMD_SET_CTCSS_110.9=110.9,CMD_SET_CTCSS_114.8=114.8,CMD_SET_CTCSS_118.8=118.8,CMD_SET_CTCSS_123=123,CMD_SET_CTCSS_127.3=127.3,CMD_SET_CTCSS_131.8=131.8,CMD_SET_CTCSS_136.5=136.5,CMD_SET_CTCSS_141.3=141.3,CMD_SET_CTCSS_146.2=146.2,CMD_SET_CTCSS_151.4=151.4,CMD_SET_CTCSS_156.7=156.7,CMD_SET_CTCSS_162.2=162.2,CMD_SET_CTCSS_167.9=167.9,CMD_SET_CTCSS_173.8=173.8,CMD_SET_CTCSS_179.9=179.9,CMD_SET_CTCSS_186.2=186.2,CMD_SET_CTCSS_192.8=192.8,CMD_SET_CTCSS_203.5=203.5,CMD_SET_CTCSS_206.5=206.5,CMD_SET_CTCSS_210.7=210.7,CMD_SET_CTCSS_218.1=218.1,CMD_SET_CTCSS_225.7=225.7,CMD_SET_CTCSS_229.1=229.1,CMD_SET_CTCSS_233.6=233.6,CMD_SET_CTCSS_241.8=241.8,CMD_SET_CTCSS_250.3=250.3,CMD_SET_CTCSS_254.1=254.1
BTN_OPT5_NOFN=DCS,CMD_SET_DCS_023=023,CMD_SET_DCS_025=025,CMD_SET_DCS_026=026,CMD_SET_DCS_031=031,CMD_SET_DCS_032=032,CMD_SET_DCS_036=036,CMD_SET_DCS_043=043,CMD_SET_DCS_047=047,CMD_SET_DCS_051=051,CMD_SET_DCS_053=053,CMD_SET_DCS_054=054,CMD_SET_DCS_065=065,CMD_SET_DCS_071=071,CMD_SET_DCS_072=072,CMD_SET_DCS_073=073,CMD_SET_DCS_074=074,CMD_SET_DCS_114=114,CMD_SET_DCS_115=115,CMD_SET_DCS_116=116,CMD_SET_DCS_122=122,CMD_SET_DCS_125=125,CMD_SET_DCS_131=131,CMD_SET_DCS_132=132,CMD_SET_DCS_134=134,CMD_SET_DCS_143=143,CMD_SET_DCS_145=145,CMD_SET_DCS_152=152,CMD_SET_DCS_155=155,CMD_SET_DCS_156=156,CMD_SET_DCS_162=162,CMD_SET_DCS_165=165,CMD_SET_DCS_172=172,CMD_SET_DCS_174=174,CMD_SET_DCS_205=205,CMD_SET_DCS_212=212,CMD_SET_DCS_223=223,CMD_SET_DCS_225=225,CMD_SET_DCS_226=226,CMD_SET_DCS_243=243,CMD_SET_DCS_244=244,CMD_SET_DCS_245=245,CMD_SET_DCS_246=246,CMD_SET_DCS_251=251,CMD_SET_DCS_252=252,CMD_SET_DCS_255=255,CMD_SET_DCS_261=261,CMD_SET_DCS_263=263,CMD_SET_DCS_265=265,CMD_SET_DCS_266=266,CMD_SET_DCS_271=271,CMD_SET_DCS_274=274,CMD_SET_DCS_306=306,CMD_SET_DCS_311=311,CMD_SET_DCS_315=315,CMD_SET_DCS_325=325,CMD_SET_DCS_331=331,CMD_SET_DCS_332=332,CMD_SET_DCS_343=343,CMD_SET_DCS_346=346,CMD_SET_DCS_351=351,CMD_SET_DCS_356=356,CMD_SET_DCS_364=364,CMD_SET_DCS_365=365,CMD_SET_DCS_371=371,CMD_SET_DCS_411=411,CMD_SET_DCS_412=412,CMD_SET_DCS_413=413,CMD_SET_DCS_423=423,CMD_SET_DCS_431=431,CMD_SET_DCS_432=432,CMD_SET_DCS_445=445,CMD_SET_DCS_446=446,CMD_SET_DCS_452=452,CMD_SET_DCS_454=454,CMD_SET_DCS_455=455,CMD_SET_DCS_462=462,CMD_SET_DCS_464=464,CMD_SET_DCS_465=465,CMD_SET_DCS_466=466,CMD_SET_DCS_503=503,CMD_SET_DCS_506=506,CMD_SET_DCS_516=516,CMD_SET_DCS_523=523,CMD_SET_DCS_526=526,CMD_SET_DCS_532=532,CMD_SET_DCS_546=546,CMD_SET_DCS_565=565,CMD_SET_DCS_606=606,CMD_SET_DCS_612=612,CMD_SET_DCS_624=624,CMD_SET_DCS_627=627,CMD_SET_DCS_631=631,CMD_SET_DCS_632=632,CMD_SET_DCS_654=654,CMD_SET_DCS_662=662,CMD_SET_DCS_664=664,CMD_SET_DCS_703=703,CMD_SET_DCS_712=712,CMD_SET_DCS_723=723,CMD_SET_DCS_731=731,CMD_SET_DCS_732=732,CMD_SET_DCS_734=734,CMD_SET_DCS_743=743,CMD_SET_DCS_754=754
BTN_OPT1_FN=VFO,CMD_SET_VFO_TOGGLE,CMD_SET_VFO_TOGGLE,VFO-A,VFO-B
BTN_OPT2_FN=
BTN_OPT3_FN=
BTN_OPT4_FN=RPT,CMD_SET_RPT_MIN=MIN,CMD_SET_RPT_PLUS=PLUS,CMD_SET_RPT_SIMPLEX=SIMPLEX
BTN_OPT5_FN=SHFT,CMD_SET_OFFSET_0100=100,CMD_SET_OFFSET_0600=600,CMD_SET_OFFSET_7600=7600,CMD_SET_OFFSET_1600=1600
; List of available commands for the current transceiver, all items from the list are bytes (reprezented as a HEX string
; use Pxxxx as 'byte' to separate two successive commands by a xxxx ms delay
; <Dxx> - numeric digits - BCD (from 9, thousands MHz to 0 - Hz)
; <Sx> - string digits - from 9 - , thousands MHz to 0 - Hz)
CMD_SET_FREQ=<D87>,<D65>,<D43>,<D21>,01
CMD_SET_SPLIT_ON=00,00,00,00,02
CMD_SET_SPLIT_OFF=00,00,00,00,82
CMD_SET_LOCK_ON=00,00,00,00,00
CMD_SET_LOCK_OFF=00,00,00,00,80
CMD_SET_PTT_ON=00,00,00,00,08
CMD_SET_PTT_OFF=00,00,00,00,88
CMD_SET_MODE_LSB=00,00,00,00,07
CMD_SET_MODE_USB=01,00,00,00,07
CMD_SET_MODE_CW=02,00,00,00,07
CMD_SET_MODE_CWR=03,00,00,00,07
CMD_SET_MODE_AM=04,00,00,00,07
CMD_SET_MODE_FM=08,00,00,00,07
CMD_SET_MODE_FM-N=88,00,00,00,07
CMD_SET_MODE_DIG=0A,00,00,00,07
CMD_SET_MODE_PKT=0C,00,00,00,07
CMD_SET_CLARIFIER_ON=00,00,00,00,05
CMD_SET_CLARIFIER_OFF=00,00,00,00,85
CMD_SET_VFO_TOGGLE=00,00,00,00,81
CMD_SET_DCS_ON=0A,00,00,00,0A
CMD_SET_ENCODER_ON=4A,00,00,00,0A
CMD_SET_ENCODER_OFF=8A,00,00,00,0A
CMD_SET_POWER_ON=00,00,00,00,00,<P1000>,00,00,00,00,0F,
CMD_SET_POWER_OFF=00,00,00,00,00,<P1000>,00,00,00,00,8F,<P1000>
CMD_SET_PWR_0.5W=
CMD_SET_PWR_1.0W=
CMD_SET_PWR_2.5W=
CMD_SET_PWR_5.0W=
CMD_SET_PWR_20.0W=
CMD_SET_PWR_45.0W=
CMD_SET_PWR_75.0W=
CMD_SET_PWR_100.0W=
CMD_SET_RPT_MIN=09,00,00,00,09
CMD_SET_RPT_PLUS=49,00,00,00,09
CMD_SET_RPT_SIMPLEX=89,00,00,00,09
CMD_SET_OFFSET_0100=00,01,00,00,F9
CMD_SET_OFFSET_0600=00,06,00,00,F9
CMD_SET_OFFSET_7600=00,76,00,00,F9
CMD_SET_OFFSET_1600=00,16,00,00,F9
CMD_SET_CTCSS_OFF=8A,00,00,00,0A
CMD_SET_CTCSS_ON=2A,00,00,00,0A
CMD_SET_CTCSS_RXON=3A,00,00,00,0A
CMD_SET_CTCSS_TXON=4A,00,00,00,0A
CMD_SET_DCS_RXON=0B,00,00,00,0A
CMD_SET_DCS_TXON=0C,00,00,00,0A
CMD_SET_CTCSS_67=06,70,06,70,0B
CMD_SET_CTCSS_69&#46;3=06,93,06,93,0B
CMD_SET_CTCSS_71&#46;9=07,19,07,19,0B
CMD_SET_CTCSS_74&#46;4=07,44,07,44,0B
CMD_SET_CTCSS_77=07,70,07,70,0B
CMD_SET_CTCSS_79&#46;7=07,97,07,97,0B
CMD_SET_CTCSS_82&#46;5=08,25,08,25,0B
CMD_SET_CTCSS_85&#46;4=08,54,08,54,0B
CMD_SET_CTCSS_88&#46;5=08,85,08,85,0B
CMD_SET_CTCSS_91&#46;5=09,15,09,15,0B
CMD_SET_CTCSS_94&#46;8=09,48,09,48,0B
CMD_SET_CTCSS_97&#46;4=09,74,09,74,0B
CMD_SET_CTCSS_100=10,00,10,00,0B
CMD_SET_CTCSS_103&#46;5=10,35,10,35,0B
CMD_SET_CTCSS_107&#46;2=10,72,10,72,0B
CMD_SET_CTCSS_110&#46;9=11,09,11,09,0B
CMD_SET_CTCSS_114&#46;8=11,48,11,48,0B
CMD_SET_CTCSS_118&#46;8=11,88,11,88,0B
CMD_SET_CTCSS_123=12,30,12,30,0B
CMD_SET_CTCSS_127&#46;3=12,73,12,73,0B
CMD_SET_CTCSS_131&#46;8=13,18,13,18,0B
CMD_SET_CTCSS_136&#46;5=13,65,13,65,0B
CMD_SET_CTCSS_141&#46;3=14,13,14,13,0B
CMD_SET_CTCSS_146&#46;2=14,62,14,62,0B
CMD_SET_CTCSS_151&#46;4=15,14,15,14,0B
CMD_SET_CTCSS_156&#46;7=15,67,15,67,0B
CMD_SET_CTCSS_162&#46;2=16,22,16,22,0B
CMD_SET_CTCSS_167&#46;9=16,79,16,79,0B
CMD_SET_CTCSS_173&#46;8=17,38,17,38,0B
CMD_SET_CTCSS_179&#46;9=17,99,17,99,0B
CMD_SET_CTCSS_186&#46;2=18,62,18,62,0B
CMD_SET_CTCSS_192&#46;8=19,28,19,28,0B
CMD_SET_CTCSS_203&#46;5=20,35,20,35,0B
CMD_SET_CTCSS_206&#46;5=20,65,20,65,0B
CMD_SET_CTCSS_210&#46;7=21,07,21,07,0B
CMD_SET_CTCSS_218&#46;1=21,81,21,81,0B
CMD_SET_CTCSS_225&#46;7=22,57,22,57,0B
CMD_SET_CTCSS_229&#46;1=22,91,22,91,0B
CMD_SET_CTCSS_233&#46;6=23,36,23,36,0B
CMD_SET_CTCSS_241&#46;8=24,18,24,18,0B
CMD_SET_CTCSS_250&#46;3=25,03,25,03,0B
CMD_SET_CTCSS_254&#46;1=25,41,25,41,0B
CMD_SET_DCS_023=00,23,00,23,0C
CMD_SET_DCS_025=00,25,00,25,0C
CMD_SET_DCS_026=00,26,00,26,0C
CMD_SET_DCS_031=00,31,00,31,0C
CMD_SET_DCS_032=00,32,00,32,0C
CMD_SET_DCS_036=00,36,00,36,0C
CMD_SET_DCS_043=00,43,00,43,0C
CMD_SET_DCS_047=00,47,00,47,0C
CMD_SET_DCS_051=00,51,00,51,0C
CMD_SET_DCS_053=00,53,00,53,0C
CMD_SET_DCS_054=00,54,00,54,0C
CMD_SET_DCS_065=00,65,00,65,0C
CMD_SET_DCS_071=00,71,00,71,0C
CMD_SET_DCS_072=00,72,00,72,0C
CMD_SET_DCS_073=00,73,00,73,0C
CMD_SET_DCS_074=00,74,00,74,0C
CMD_SET_DCS_114=01,14,01,14,0C
CMD_SET_DCS_115=01,15,01,15,0C
CMD_SET_DCS_116=01,16,01,16,0C
CMD_SET_DCS_122=01,22,01,22,0C
CMD_SET_DCS_125=01,25,01,25,0C
CMD_SET_DCS_131=01,31,01,31,0C
CMD_SET_DCS_132=01,32,01,32,0C
CMD_SET_DCS_134=01,34,01,34,0C
CMD_SET_DCS_143=01,43,01,43,0C
CMD_SET_DCS_145=01,45,01,45,0C
CMD_SET_DCS_152=01,52,01,52,0C
CMD_SET_DCS_155=01,55,01,55,0C
CMD_SET_DCS_156=01,56,01,56,0C
CMD_SET_DCS_162=01,62,01,62,0C
CMD_SET_DCS_165=01,65,01,65,0C
CMD_SET_DCS_172=01,72,01,72,0C
CMD_SET_DCS_174=01,74,01,74,0C
CMD_SET_DCS_205=02,05,02,05,0C
CMD_SET_DCS_212=02,12,02,12,0C
CMD_SET_DCS_223=02,23,02,23,0C
CMD_SET_DCS_225=02,25,02,25,0C
CMD_SET_DCS_226=02,26,02,26,0C
CMD_SET_DCS_243=02,43,02,43,0C
CMD_SET_DCS_244=02,44,02,44,0C
CMD_SET_DCS_245=02,45,02,45,0C
CMD_SET_DCS_246=02,46,02,46,0C
CMD_SET_DCS_251=02,51,02,51,0C
CMD_SET_DCS_252=02,52,02,52,0C
CMD_SET_DCS_255=02,55,02,55,0C
CMD_SET_DCS_261=02,61,02,61,0C
CMD_SET_DCS_263=02,63,02,63,0C
CMD_SET_DCS_265=02,65,02,65,0C
CMD_SET_DCS_266=02,66,02,66,0C
CMD_SET_DCS_271=02,71,02,71,0C
CMD_SET_DCS_274=02,74,02,74,0C
CMD_SET_DCS_306=03,06,03,06,0C
CMD_SET_DCS_311=03,11,03,11,0C
CMD_SET_DCS_315=03,15,03,15,0C
CMD_SET_DCS_325=03,25,03,25,0C
CMD_SET_DCS_331=03,31,03,31,0C
CMD_SET_DCS_332=03,32,03,32,0C
CMD_SET_DCS_343=03,43,03,43,0C
CMD_SET_DCS_346=03,46,03,46,0C
CMD_SET_DCS_351=03,51,03,51,0C
CMD_SET_DCS_356=03,56,03,56,0C
CMD_SET_DCS_364=03,64,03,64,0C
CMD_SET_DCS_365=03,65,03,65,0C
CMD_SET_DCS_371=03,71,03,71,0C
CMD_SET_DCS_411=04,11,04,11,0C
CMD_SET_DCS_412=04,12,04,12,0C
CMD_SET_DCS_413=04,13,04,13,0C
CMD_SET_DCS_423=04,23,04,23,0C
CMD_SET_DCS_431=04,31,04,31,0C
CMD_SET_DCS_432=04,32,04,32,0C
CMD_SET_DCS_445=04,45,04,45,0C
CMD_SET_DCS_446=04,46,04,46,0C
CMD_SET_DCS_452=04,52,04,52,0C
CMD_SET_DCS_454=04,54,04,54,0C
CMD_SET_DCS_455=04,55,04,55,0C
CMD_SET_DCS_462=04,62,04,62,0C
CMD_SET_DCS_464=04,64,04,64,0C
CMD_SET_DCS_465=04,65,04,65,0C
CMD_SET_DCS_466=04,66,04,66,0C
CMD_SET_DCS_503=05,03,05,03,0C
CMD_SET_DCS_506=05,06,05,06,0C
CMD_SET_DCS_516=05,16,05,16,0C
CMD_SET_DCS_523=05,23,05,23,0C
CMD_SET_DCS_526=05,26,05,26,0C
CMD_SET_DCS_532=05,32,05,32,0C
CMD_SET_DCS_546=05,46,05,46,0C
CMD_SET_DCS_565=05,65,05,65,0C
CMD_SET_DCS_606=06,06,06,06,0C
CMD_SET_DCS_612=06,12,06,12,0C
CMD_SET_DCS_624=06,24,06,24,0C
CMD_SET_DCS_627=06,27,06,27,0C
CMD_SET_DCS_631=06,31,06,31,0C
CMD_SET_DCS_632=06,32,06,32,0C
CMD_SET_DCS_654=06,54,06,54,0C
CMD_SET_DCS_662=06,62,06,62,0C
CMD_SET_DCS_664=06,64,06,64,0C
CMD_SET_DCS_703=07,03,07,03,0C
CMD_SET_DCS_712=07,12,07,12,0C
CMD_SET_DCS_723=07,23,07,23,0C
CMD_SET_DCS_731=07,31,07,31,0C
CMD_SET_DCS_732=07,32,07,32,0C
CMD_SET_DCS_734=07,34,07,34,0C
CMD_SET_DCS_743=07,43,07,43,0C
CMD_SET_DCS_754=07,54,07,54,0C
; read command format
; <priority>,<when to read>,<command - variable length>,<separator>,<nr.of.expected.bytes>,<rec_byte_1>,...,<rec byte_n>
;       <priority> - 01-each loop, 02-from time to time (currently one from 4 loops)
;      <when to read> - 00-both during Rx and Tx, 01-during Rx only, 02-during Tx only (discarded/not sent otherwise)
;      <command - variable length> - see list of available commands format above (same as for the "blind commands", with no feedback)
;      <separator> - <R> - end command separator (<R>)
;      <nr_rec_bytes> - number of data bytes expected to be received
;      <rec_byte_x> - what that byte represent
;                - follows the rule from the SEND commands to define data
;                - <00> - byte not containing a farameter to be read - will be discarded
;                 - list of possible byte value (as 2 digits hex if numeric value or Sx if char value) and corresponding parameter value. Take care to use a valid parameter value, this is not checked for errors.
;                  A binary byte followed by '/' can be used as a mask for that byte if only some bits are to be used
CMD_READ_FREQ&MODE=01,01,00,00,00,00,03,<R>,05,<D87>,<D65>,<D43>,<D21>,<00=LSB;01=USB;02=CW;03=CWR;04=AM;06=WFM;08=FM;0A=DIG;0C=PKT>
CMD_READ_PTT=04,00,00,00,00,00,F7,<R>,01,<0xxxxxxx=ON;1xxxxxxx=OFF>
CMD_READ_VFO=04,01,<RE0055>,<R>,02,<xxxxxxx0=VFO-A;xxxxxxx1=VFO-B>,<xxxxxxxx>
CMD_READ_SMETER=01,01,00,00,00,00,E7,<R>,01,<xxxx0000=S0;xxxx0001=S1;xxxx0010=S2;xxxx0011=S3;xxxx0100=S4;xxxx0101=S5;xxxx0110=S6;xxxx0111=S7;xxxx1000=S8;xxxx1001=S9;xxxx1010=S9+10dB;xxxx1011=S9+20dB;xxxx1100=S9+30dB;xxxx1101=S9+40dB;xxxx1110=S9+50dB;xxxx1111=S9+60dB>
CMD_READ_PWR=01,02,00,00,00,00,BD,<R>,02,<vvvvxxxx>,<xxxxxxxx>
CMD_READ_ALC=01,02,00,00,00,00,BD,<R>,02,<xxxxvvvv>,<xxxxxxxx>
CMD_READ_SWR=01,02,00,00,00,00,BD,<R>,02,<xxxxxxxx>,<vvvvxxxx>
CMD_READ_MOD=01,02,00,00,00,00,BD,<R>,02,<xxxxxxxx>,<xxxxvvvv>
CALIB_SMETER=
CALIB_PWR=<MAX=0F>,<0=0;07=2.5;0F=5>
CALIB_SWR=<MAX=0F>,<00=1;02=1.1;04=1.2;05=1.5;06=2;08=3;09=5;0B=10>
CALIB_ALC=<MAX=0F>,<0=0;07=50;0F=100>
CALIB_MOD=<MAX=0F>,<0=0;07=50;0F=100>
;CMD_READ_SQUELCH=0A,05,01,00,00,00,00,E7,<R>,<01>,<10000000/01=ON;10000000/00=OFF>
; list of commands to be sent at startup (optional)
STARTUP=CMD_SET_PTT_OFF,CMD_SET_LOCK_OFF,CMD_SET_PARAMS_FROM_INTERFACE
; list of commands for the parameters feedback
POLLING=CMD_READ_FREQ&MODE,CMD_READ_PTT,CMD_READ_VFO,CMD_READ_SMETER,CMD_READ_SWR,CMD_READ_PWR,CMD_READ_ALC,CMD_READ_MOD
; list of commands to be sent at startup (usually read different parameters in order to be able to work after that without feedback, for max. responsiveness
STARTUP=CMD_READ_FREQ,CMD_READ_MODE,CMD_READ_MODE,CMD_READ_MODE,CMD_READ_MODE
Post by yo3ggx » Fri Sep 25, 2015 10:33 pm
Can I update your previous config file in the repository or you want to be saved as a different one?
Post by MysticFire » Fri Sep 25, 2015 10:42 pm
You can sure. But please this one
Brand=Yaesu
Model=FT857
sigRadios=$1gR@d10s
LST1NAME=MODE
LST2NAME=PWR
BTN_OPT2_NOFN=
BTN_OPT4_NOFN=CTCSS,CMD_SET_CTCSS_67=67,CMD_SET_CTCSS_69.3=69.3,CMD_SET_CTCSS_71.9=71.9,CMD_SET_CTCSS_74.4=74.4,CMD_SET_CTCSS_77=77,CMD_SET_CTCSS_79.7=79.7,CMD_SET_CTCSS_82.5=82.5,CMD_SET_CTCSS_85.4=85.4,CMD_SET_CTCSS_88.5=88.5,CMD_SET_CTCSS_91.5=91.5,CMD_SET_CTCSS_94.8=94.8,CMD_SET_CTCSS_97.4=97.4,CMD_SET_CTCSS_100=100,CMD_SET_CTCSS_103.5=103.5,CMD_SET_CTCSS_107.2=107.2,CMD_SET_CTCSS_110.9=110.9,CMD_SET_CTCSS_114.8=114.8,CMD_SET_CTCSS_118.8=118.8,CMD_SET_CTCSS_123=123,CMD_SET_CTCSS_127.3=127.3,CMD_SET_CTCSS_131.8=131.8,CMD_SET_CTCSS_136.5=136.5,CMD_SET_CTCSS_141.3=141.3,CMD_SET_CTCSS_146.2=146.2,CMD_SET_CTCSS_151.4=151.4,CMD_SET_CTCSS_156.7=156.7,CMD_SET_CTCSS_162.2=162.2,CMD_SET_CTCSS_167.9=167.9,CMD_SET_CTCSS_173.8=173.8,CMD_SET_CTCSS_179.9=179.9,CMD_SET_CTCSS_186.2=186.2,CMD_SET_CTCSS_192.8=192.8,CMD_SET_CTCSS_203.5=203.5,CMD_SET_CTCSS_206.5=206.5,CMD_SET_CTCSS_210.7=210.7,CMD_SET_CTCSS_218.1=218.1,CMD_SET_CTCSS_225.7=225.7,CMD_SET_CTCSS_229.1=229.1,CMD_SET_CTCSS_233.6=233.6,CMD_SET_CTCSS_241.8=241.8,CMD_SET_CTCSS_250.3=250.3,CMD_SET_CTCSS_254.1=254.1
BTN_OPT5_NOFN=DCS,CMD_SET_DCS_023=023,CMD_SET_DCS_025=025,CMD_SET_DCS_26=026,CMD_SET_DCS_031=031,CMD_SET_DCS_032=032,CMD_SET_DCS_036=036,CMD_SET_DCS_043=043,CMD_SET_DCS_47=047,CMD_SET_DCS_051=051,CMD_SET_DCS_053=053,CMD_SET_DCS_054=054,CMD_SET_DCS_065=065,CMD_SET_DCS_071=071,CMD_SET_DCS_072=072,CMD_SET_DCS_073=073,CMD_SET_DCS_074=074,CMD_SET_DCS_114=114,CMD_SET_DCS_115=115,CMD_SET_DCS_116=116,CMD_SET_DCS_122=122,CMD_SET_DCS_125=125,CMD_SET_DCS_131=131,CMD_SET_DCS_132=132,CMD_SET_DCS_134=134,CMD_SET_DCS_143=143,CMD_SET_DCS_145=145,CMD_SET_DCS_152=152,CMD_SET_DCS_155=155,CMD_SET_DCS_156=156,CMD_SET_DCS_162=162,CMD_SET_DCS_165=165,CMD_SET_DCS_172=172,CMD_SET_DCS_174=174,CMD_SET_DCS_205=205,CMD_SET_DCS_212=212,CMD_SET_DCS_223=223,CMD_SET_DCS_225=225,CMD_SET_DCS_226=226,CMD_SET_DCS_243=243,CMD_SET_DCS_244=244,CMD_SET_DCS_245=245,CMD_SET_DCS_246=246,CMD_SET_DCS_251=251,CMD_SET_DCS_252=252,CMD_SET_DCS_255=255,CMD_SET_DCS_261=261,CMD_SET_DCS_263=263,CMD_SET_DCS_265=265,CMD_SET_DCS_266=266,CMD_SET_DCS_271=271,CMD_SET_DCS_274=274,CMD_SET_DCS_306=306,CMD_SET_DCS_311=311,CMD_SET_DCS_315=315,CMD_SET_DCS_325=325,CMD_SET_DCS_331=331,CMD_SET_DCS_332=332,CMD_SET_DCS_343=343,CMD_SET_DCS_346=346,CMD_SET_DCS_351=351,CMD_SET_DCS_356=356,CMD_SET_DCS_364=364,CMD_SET_DCS_365=365,CMD_SET_DCS_371=371,CMD_SET_DCS_411=411,CMD_SET_DCS_412=412,CMD_SET_DCS_413=413,CMD_SET_DCS_423=423,CMD_SET_DCS_431=431,CMD_SET_DCS_432=432,CMD_SET_DCS_445=445,CMD_SET_DCS_446=446,CMD_SET_DCS_452=452,CMD_SET_DCS_454=454,CMD_SET_DCS_455=455,CMD_SET_DCS_462=462,CMD_SET_DCS_464=464,CMD_SET_DCS_465=465,CMD_SET_DCS_466=466,CMD_SET_DCS_503=503,CMD_SET_DCS_506=506,CMD_SET_DCS_516=516,CMD_SET_DCS_523=523,CMD_SET_DCS_526=526,CMD_SET_DCS_532=532,CMD_SET_DCS_546=546,CMD_SET_DCS_565=565,CMD_SET_DCS_606=606,CMD_SET_DCS_612=612,CMD_SET_DCS_624=624,CMD_SET_DCS_627=627,CMD_SET_DCS_631=631,CMD_SET_DCS_632=632,CMD_SET_DCS_654=654,CMD_SET_DCS_662=662,CMD_SET_DCS_664=664,CMD_SET_DCS_703=703,CMD_SET_DCS_712=712,CMD_SET_DCS_723=723,CMD_SET_DCS_731=731,CMD_SET_DCS_732=732,CMD_SET_DCS_734=734,CMD_SET_DCS_743=743,CMD_SET_DCS_754=754
BTN_OPT2_FN=
BTN_OPT3_FN=
CMD_SET_PWR_0.5W=
CMD_SET_PWR_1.0W=
CMD_SET_PWR_2.5W=
CMD_SET_PWR_5.0W=
CMD_SET_PWR_20.0W=
CMD_SET_PWR_45.0W=
CMD_SET_PWR_75.0W=
CMD_SET_PWR_100.0W=
CMD_SET_CTCSS_69.3=06,93,06,93,0B
CMD_SET_CTCSS_71.9=07,19,07,19,0B
CMD_SET_CTCSS_74.4=07,44,07,44,0B
CMD_SET_CTCSS_79.7=07,97,07,97,0B
CMD_SET_CTCSS_82.5=08,25,08,25,0B
CMD_SET_CTCSS_85.4=08,54,08,54,0B
CMD_SET_CTCSS_88.5=08,85,08,85,0B
CMD_SET_CTCSS_91.5=09,15,09,15,0B
CMD_SET_CTCSS_94.8=09,48,09,48,0B
CMD_SET_CTCSS_97.4=09,74,09,74,0B
CMD_SET_CTCSS_103.5=10,35,10,35,0B
CMD_SET_CTCSS_107.2=10,72,10,72,0B
CMD_SET_CTCSS_110.9=11,09,11,09,0B
CMD_SET_CTCSS_114.8=11,48,11,48,0B
CMD_SET_CTCSS_118.8=11,88,11,88,0B
CMD_SET_CTCSS_127.3=12,73,12,73,0B
CMD_SET_CTCSS_131.8=13,18,13,18,0B
CMD_SET_CTCSS_136.5=13,65,13,65,0B
CMD_SET_CTCSS_141.3=14,13,14,13,0B
CMD_SET_CTCSS_146.2=14,62,14,62,0B
CMD_SET_CTCSS_151.4=15,14,15,14,0B
CMD_SET_CTCSS_156.7=15,67,15,67,0B
CMD_SET_CTCSS_162.2=16,22,16,22,0B
CMD_SET_CTCSS_167.9=16,79,16,79,0B
CMD_SET_CTCSS_173.8=17,38,17,38,0B
CMD_SET_CTCSS_179.9=17,99,17,99,0B
CMD_SET_CTCSS_186.2=18,62,18,62,0B
CMD_SET_CTCSS_192.8=19,28,19,28,0B
CMD_SET_CTCSS_203.5=20,35,20,35,0B
CMD_SET_CTCSS_206.5=20,65,20,65,0B
CMD_SET_CTCSS_210.7=21,07,21,07,0B
CMD_SET_CTCSS_218.1=21,81,21,81,0B
CMD_SET_CTCSS_225.7=22,57,22,57,0B
CMD_SET_CTCSS_229.1=22,91,22,91,0B
CMD_SET_CTCSS_233.6=23,36,23,36,0B
CMD_SET_CTCSS_241.8=24,18,24,18,0B
CMD_SET_CTCSS_250.3=25,03,25,03,0B
CMD_SET_CTCSS_254.1=25,41,25,41,0B
CALIB_SMETER=
Post by yo3ggx » Fri Sep 25, 2015 11:27 pm
Updated.
Thank you for your contribution.
Post by MysticFire » Fri Sep 25, 2015 11:55 pm
Great. Thanks Dan
balans
Post by balans » Sat Sep 26, 2015 12:53 pm
Hi Misticfire,
thnx for posting! , i used some of you`re commands i did not have yet.
73, PA1ZKH
Post by MysticFire » Sat Sep 26, 2015 1:49 pm
Great. Enjoy it. I had my topic on rpt and ctcss/DCS. What i can't find yet are the byte sequences for the RF Power. Maybe portmon is my friend xD
Post by yo3ggx » Sat Sep 26, 2015 2:39 pm
Do not forget to save the EEPROM area with the calibration data before playing with EEPROM write commands.
You can use FT817 commander for that purpose till my little Java app will be ready.
